RE: A question for Skymaster Phantom Owners
I think I found a solution...although a bit of a compromise. If I put a washer under each of the two outer (toward the root of the wing) retract screws it will raise the retracted wheel a bit in the well giving me a little more room. It almost makes it when the wheel is aligned with the fuse (zero toe) but with a bit of toe out I think it will all work.
