RCU Forums - View Single Post - CMP Katana 140 V2 CG
Old 10-14-2011 | 10:37 AM
opjose's Avatar
opjose
Default RE: CMP Katana 140 V2 CG
What you have is perfect.
You can slightly modify the servo cover to become the pull-pull exit. Just don't feel you need to over do it.
Also remember that moving 2oz off the tail removes the requirement for 8+10oz off the nose.
The lever arm moment of that long tail has a dramatic effect on small weight offsets.
The Pull-Pull is worth doing.
