RE: Ordering sig se tomorrow
Your will love the way it flys. I built mine when they first came out and it is still flying great! I use a wire tie to hold the wings on and that works well. The best mod in my opinion is to mount the motor on its side. This redirects the exhaust discharge underneath the plane and prevents fuel creep under the canopy and wing joint. I flew this plane two years before cutting the nose off and making this mod. The other item you will need to change is the landing gear. The kit gear will not be tall enough to swing the larger 4 stroke prop. It is even to short for the two stroke motors.
