Yeah I had it ready to go and then I decided to convert gear, now I just have to run a few more servo extension and change some airline connections since I removed part of the air system. I'm also going drill my servo horns while its apart, I have my end points all the way down and still more throw than needed. I will drill and tap new holes closer in on the servo arm so I can increase the end points. The way it is would work but kills the resolution on the servo. SWBs are really more for 3D planes, wish I would have went with just a regular metal servo arms from JR or something. [&:] oh well lesson learned for next jet.
ORIGINAL: icepilot
ORIGINAL: FenderBean
Yelp your right simple fix thanks. When gear is up you can rotate the wheel if the servo is not install.
Yep, did that one my SM a few times!
Ready for maiden soon??
