ORIGINAL: flyingagin
My carb is stuck on the engine. Tried to get it off several times during this current rebuild I am doing. But it just wont come loose. Afraid to put any more pressur on it and destroy it or the engine.
The draw bar on these engines kinks the edge of the carb neck a bit. I had a hard time getting my carb off when I took the pics in the other thread I linked to earlier. I loosen the screw and try pushing on the draw bar screw itself to push the back end of the draw bar away from the carb neck. After doing this, I was able to get the carb to wiggle a little and get it free. The two-piece draw bars dont need to be super tight to hold the carb in. If its got a lot of castor sludge around the base of the carb, try heating it up good and hot with a hair dryer or heat gun after knocking the draw bar loose.
Here's my running .65
