RE: Setting up a DLE20
The "fibre" horn is supplied to lengthen the throttle horn on the carb and if used your metal to metal problem does not exist!
I use the fibre horn to allow a choke servo to be used. There is very little pressure on a throttle to servo linkage so I do not
see where you would have a problem.
