RCU Forums - View Single Post - which motor?
Thread: which motor?
Old 10-16-2011 | 09:40 AM
asupervee72
Default RE: which motor?
The plan is to run 4s. Went with the tacon cause the exceed is 20 g heavier and I read about cg issues with the heavier motors. Also the exceed seemed like overkill. I got it all mounted and am just waiting for my new tx and rx to come in.
I will be starting with a 10 x 7. An 11 inch prop will just clear the ground.
Does anyone know what kind of timing should be on the motor? I have the esc up to 22.5 degrees of timing. 26.25 would be the next and final step on my esc.
I would like to cover the cheeks somehow because it would improve the looks for sure.
