RCU Forums - View Single Post - Hot wire foam cutter
Old 10-16-2011 | 05:05 PM
  #32
OzMo's Avatar
OzMo
Default RE: Hot wire foam cutter
HI,
Some say metal patterns act as a heat sink and slow the wire down. I wonder if the tape is not as much of a heat sink and would work OK. IF so stainded glass makers use a thin (1/2") tape to edge the glass pieces then they solder over these to make it look like lead. Copper foil tape? That would be a handy size.
