ORIGINAL: jetflyr
ORIGINAL: Tip22v
SNIP>how do I get the 4mm tubing onto the fuel filter nipples that are much larger than 4mm? The manual says to heat up the ends of the tubing but that still seems like quite a stretch.
Regards,
Tom
I have found that the easiest way is to take a pair of fine-tipped needle nose pliers and put them inside the tubing, stretch, move it further in and stretch then slide it over the nipple. Simple, fast and you can't burn yourself.
Greg
I'll second that! Works like a champ.
I refined the drawing a bit more to help with a little confusion
Mike
