Aeroworks Freestyle Extra 260 QB-L
Aeroworks is proud to add the new Freestyle Extra 260 QB-L (Quick Build-Light Series) to our growing line of airplanes. Designed with the demanding 3D pilot in mind, this new airplane features many exciting and revolutionary concepts that are sure to make it the hit of your hangar. The Freestyle Extra 260 QB-L is the first in the new QB-L Series and it is sure to impress with its light weight build quality and its impressive airframe strength and longevity. The new QB-L features all of the Quick Build characteristics that Aeroworks has been known for, assembling the new Freestyle Extra 260 QB-L can be done is as little as 6 hours!
Included with the new Freestyle Extra 260 QB-L is an extensive hardware package that includes Carbon main landing gear, wing tube and the new, non-flex carbon control horns. All of these accessories are designed to be rigid and strong while providing the lightest weight possible for an airplane this size. Ball links have been provided for the smoothest in control surface movement while still allowing for 50+ Degrees of surface deflection on the Ailerons and Rudder with over 60 Degrees of deflection on the elevator! Motor mounting hardware has been provided to aid in mounting most motors and the firewall has been pre-drilled for many popular motor options!
The airframe itself features a large wing to provide an incredibly low wing loading, perfect for 3D flying! The new wing design also features both outboard and inboard Side Force Generators (SFG's) these SFG’s are pre-mounted and can be removed in seconds if desired. Along with the new wing design are the airfoiled tail surfaces that provide great control authority even at low speeds. These extra features make the Freestyle Extra 260 QB-L one of the most responsive 3D airplanes in its class. The Freestyle Extra 260 QB-L extensive build features include; pre-mounted cowling, pre-mounted wheel pants, quick release pre-mounted canopy and a large battery tray that will accommodate 3 cell to 5 cell batteries.
Aeroworks is excited to introduce our new line of QB-L airplanes starting with the Freestyle Extra 260 QB-L. With 20 years in the industry, you can be assured that Aeroworks will be here to provide you with the amazing product support that we have been known for. Hurry into your local Aeroworks dealer to see the Freestyle Extra 260 QB-L in person or continue reading to learn more about the new Freestyle Extra 260 QB-L and all of its exciting new features!
Specs:
Wing Span: 52”
Wing Area: 560
Fuse Length (Rudder to Spinner) 47”
Weight w/o Battery 53.5 Ounces
Key Features:
· Light Weight Design
· Carbon Wing Tube, Main Gear and Control Horns
· Drop In installation for Hacker A30-12XL or Torque 2814T/820
· Pre-mounted canopy with quick release latch
· Pre-mounted cowling
· Airfoiled tail surfaces
· Inboard and Outboard SFG’s
· QB Quality and Fast Build Time
The Manual, Slide Show, and Flying Video will be up as soon as possible. Thanks again for all of the interest in this airplane, I'm excited to get it out to all of you!
http://aero-works.net/store/detail.aspx?ID=496
