RCU Forums - View Single Post - K&B .61
Thread: K&B .61
Old 10-17-2011 | 04:34 PM
flyingagin's Avatar
flyingagin
Default RE: K&B .61
ORIGINAL: coriolan
You need to remove the wrist pin trough the back after removing the access cap(part #25-6191)
http://www.mecoa.com/kb/61/6550-exp.pdf
Then the piston and sleeve can come out, unless you have a brand new spare don't remove the ring from the piston as it will distord and be ruined, here is how to instal new ring:
http://www.mecoa.com/faq/rings/install/install.htm
the ring insta link was great info I saved that info as I have a rebuild comming up soon on a Saito
<br type="_moz" />
