ORIGINAL: thepamster
Hi Ameyam ,
I see that you have that EZ connector on that servo, temporarily I hope. Please resist the urge to use that as those things have no place at all in any powered aircraft, especially gassers. They will come loose, in more ways than one.
Just an opinion though.
The Pamster
thepamster..............I must respectively disagree with your comments on the EZ connectors. I have used them in all of my planes since 1982 and I have never had a problem or failure with them. I have heard this over and over again.......that they are a problem............but I have never experienced a problem and I use them not only on throttles but other control surfaces as well. Of course a preflight everytime you fly......as you should.......helps prevent all sorts of problems like loose EZ connectors, loose hinges, loose engines and motor mounts....etc.
Cheers,
Andy
