RE: Raptor G2 Main Rotor not spinning fast enough
It may be a similar problem... it's not just "out of synch" though... The tail rotor spins a million miles per hour and the main rotor just kind of lazily spins around. It gains eventually gains some speed if I rev the motor up but I stopped fooling with it to avoid doing any more damage. Probably played with it for a maybe 5 minutes max... and felt like it was 4.5 minutes too long after the fact. So you're saying the problem is probably the main gear where it attaches to the main shaft? Is that a beginner-level repair or should I seek more experienced guidance?
