RCU Forums - View Single Post - Adding Nose Weight
Old 10-18-2011 | 11:20 AM
MajorTomski's Avatar
MajorTomski
Default RE: Adding Nose Weight
On my last two large models (Green Tigermoth and BUSA E-III/90) I've match drilled fishing weights to the front of the fiberglass engine mount then tapped the holes in the mount and screw the fishing weights to the mount. Minimizes the amount of weight needed by getting it as far forward as possible.
You may look in to a heavey hub too.
