RCU Forums - View Single Post - Setting up a DLE20
Old 10-18-2011 | 12:19 PM
a1pcfixer's Avatar
a1pcfixer
My Feedback: (7)
Default RE: Setting up a DLE20
ORIGINAL: ameyam
the bracing will be required................ without the bracing the rod will just flex out of alignment.
Correct.
By the way, is the nyrod only for preventing metal to metal contact? If so, there is no point in getting it, ball links on both sides will serve the purpose. I may need to use 4-40 though as 2-56 full threaded isint available on Tower either
Partially so, it also gives you a sleeve for the throttle rod(inner nyrod) to slide in.
Otherwise, you'd need something to support a solid rod if ya go that route.
By default the 8FG / TM-8 module comes set to 8 channels.
Ameyam
Hmm, the one I'm looking at has no module, it's integrated right into the case;
http://www.towerhobbies.com/products.../futk8010.html
And comes with a R6207SB rcv;
http://www3.towerhobbies.com/cgi-bin...?&I=LXAVCR&P=V
I don't think TH/Futaba sells any Futaba FASST tx's with modules any more.
They might have a few discontinued they're unloading. Check their Scrath & Dent section.
Ask about such in the TH/Futaba Support section;
http://www.rcuniverse.com/forum/forumid_125/tt.htm
