RCU Forums - View Single Post - Adding Nose Weight
Old 10-18-2011 | 12:54 PM
boxbeam
My Feedback: (188)
Default RE: Adding Nose Weight
Wish I could put a nose weight on the engine shaft, but being the older style Enya, the prop nut goes through the prop and into a much shorter threaded shaft. The top of the engine mount was one of my first thoughts. The engine is inverted so attaching the weight should be easy. It just seemed like a lot of weight that I had to add, and I was very weight consious while building.
