ORIGINAL: bigjoe623
Its one molded piece. If you look at the picture, there is a pin that was molded onto the bottom of the knuckle that sits in a hole on the lower arm. Similar to a lower ball joint.
ah, OK.
well, on the one hand i understand your frustration.
on the other, i can see why redcat didnt warrenty. while you say you got it out of the box like that, it does look used due to the hair.
now, i had a sumo and know how little use it takes to get hair around the dogbone. the sumo practially attracts dust and hair to it!
I could get you the parts you need for $10.20 shipped(my cost)
