ORIGINAL: Snook Man
The TMaxx uses a Transmission, not a center differential. It is totally normal for the spur not to spin when you push the truck forward due to a one way bearing located on the primary shaft. The black transmission with reverse also has 2 clutches on the forward and reverse gear of the output shaft. There is also a clutch for the 2 speed shift.
why are you whispering?
