RE: G38 with a bent crank
This G38 is one of the older ones with the steel prop hub. Is it possible to update this to the new hub? Is the crank the same taper etc. ?
I see I can buy the new short flywheel hub with the magnet installed and a sensor and bracket for under $30. It looks like it would require the purchase of the 2 bolt prop hub to complete the installation minus the ignition. Anyone gone this route before with the older G38?
John
