RCU Forums - View Single Post - E Flight Phantom F-4-Turbine conversion
Old 10-19-2011 | 01:54 PM
Dave Wilshere
Default RE: E Flight Phantom F-4-Turbine conversion
Cracking on with the wings, started to put the servos in and control horns. Hinges in the surface side-typical E-Flight quality, everything fits, quality is good. Panel is not heavy.
Larger servos might be an issue as they side angled on the covers, but the surfaces are small, so 2.5kg plus should be fine.
Dw
ID:	1676561   Click image for larger version
ID:	1676562   Click image for larger version
