RCU Forums - View Single Post - G38 prop hub-out with the old?
Old 10-19-2011 | 04:17 PM
Scota4570
Default RE: G38 prop hub-out with the old?
That is pretty much what I did.
The two pins cane out easy enough with a well fitted punch driving into a bench block with a hole a little larger than the pins. I put them back though. I'll take them back out. Did you use sticky back sandpaper on the prop driver or knurl it? Just leave it smooth?
