RCU Forums - View Single Post - Wing area on 24% CA Extra
Old 09-02-2003 | 04:22 PM
Scoubidou's Avatar
Scoubidou
My Feedback: (17)
Default Wing area on 24% CA Extra
Nice pic Tipover. Good luck for the maiden flight!
I have the same comment on the wing area. I have measured it at 855sqin wing area without fuse and CA say 890sqin area??
It's is really short for 73'' wing. Forget the low speed landing except with flaperons!!
1) Where did you put the servos and battery pack (ignition+receiver)?
2) Did you use the MK bellcrank system for elevator?
3) Which wheels did you use?
4) Which engine mount?
Thanks to share the info with us. I will be the last one to built it and every time will be better, if we work all together to improve it!!
Scou.
