ORIGINAL: Campgems
Guys, you are making the four stroke sound like you need to be a faa certified mechanic to even think about taking it out of the box.
To set up a 2 stroke.
You position it on the motor mounts, drill and screw it to the motor mounts. run the throttle linkage to the throtle servo. Hook a fuel line from the carb to the klunk of the tank. Run a fuel line from the muffler to the tank vent. Hook up a glow ignighter, Start the engine. Tune the high speed needle. Tune the idle mix. Go back and tune them again. fly the plane.
To set up a 4 storke.
Not much difference isthere.
Don
You left off the break in and setup. Valve adjustment, differances in tuning (hard to tune a 4 stroke by ear, and other. That said I would put a cheap 2 stroke on a trainer, if nothing else than the fact it costs less to lose in a crash. Keep the four stroke for your future low wing trainer. Nothing wrong with having an older trainer to warm up with before flying the low wing craft.
