RCU Forums - View Single Post - Sebart Wind S Pro
Old 10-21-2011 | 01:43 AM
  #429
talk the torque
Default RE: Sebart Wind S Pro
Thanks Chester I will look into those as well. Here is a thought, now that you have worked with those hinges, do you think if you shaped a 3mm steel rod as you have but instead of spinning it in a dremel rather heat until its very hot with a gas torch that it would work to melt the hinges out? Otherwise I will just do what you have done, I'm doing all the hinges so hope it goes well
Just getting some ideas here [&:]
