RCU Forums - View Single Post - Why use a 3-bladed prop
Old 10-21-2011 | 07:53 AM
winglift
My Feedback: (10)
Default RE: Why use a 3-bladed prop
ORIGINAL: Dean Pappas
ORIGINAL: winglift
When and why would you want to use a 3-bladed prop? Is it better than a 2-bladed prop? What is the rule of thumb in choosing which one to use?
Hello Winglift,
When it comes right down to it, you only want to run a 3-blader when you want to run an engine whose RPM sweet-spot and max horsepower output, when combined with a ''low'' pitch, say 10 or 11 inches for good downline braking, would force you to use too big a diameter, just to absorb the available horsepower. The big diameter, combined with the higher RPM, would then cause the tip velocities to be too high, making lots of prop noise (howl). The 3-blader simply lets you absorb that max power level at the same RPM and pitch, and still keep tip velocities down.
The price you pay in decreased prop efficiency (a handful of percent) is more than offset by running the engine in the sweet-spot, rather than lugged-down. If not, stick with the two-blader.
I hope that helps,
Dean Pappas
That helps a great deal! I apologize for this question, but how do you know what the sweet-spot is on an engine? In my case I use about 1/3 to 1/2 throttle and the FZ70 pulls the BeatOn50 quite well, so is the sweet-spot where I set the engine for most maneuvers or is there more to it than that?
