RCU Forums - View Single Post - a hProp drilled wrong OOPS!!!
Old 10-22-2011 | 07:25 AM
Tired Old Man
Default RE: a hProp drilled wrong OOPS!!!
The difference with the 3w and ZDZ hubs is they have a screw passing through the hole adding a compression load at exactly the location of the hole. Re-drilling holes is not an issue. Leaving open ones unsupported in a prop hub is not a good thing to do. Plugging the open holes might save you or others your health, or more.
