RE: E Flight Phantom F-4-Turbine conversion
Bit more today, the pre formed legs are different to the std wire supplied with the EFLG 230's, note the bigger coil, pre bent position leaves the wheel just forward of the centre (perfect)
When you set the control surfaces, make sure you leave a large enough gap as the hinge line angles mean the gaps close with movement.
Dw
