RE: I'm so disappointed with THE QUAKE 8e....
if you are wanting a hardened steel ring/pinionupgrade i asked redcat to e-mail me when it come in stock.i can let you know when that happens (yeah right!).or if you want the # i can look for it.i put earthquake tires on the 15t aftershock and within minutes the rear dif blew.nothing left of the pinion.imo its a pinion temper problem not a backlash problem.if the pinion was loose it would of took the teeth out and left the collar.
