Weav, Fred,
I did send you a PM, did you receive it?
The post, short update about the ,
The Simla canopy.
Carving and sanding of the canopy plug is complicated and takes some time.
The contour, visible on my pictures I make from all known POV’s (point of view) have to be the same as on any different original photograph or picture.
My assistance again is “Paint” the drawing program .
I can make the pictures as shown in example 1, after that lower the plug on the location to compare by use of paint picture 2, check differences with the line of constant length (pixels) and change the shape.
The result of course is the exact copy but that will take some time. The plug will be very valuable because with that I can make more duplicates if I want to.
More to come
The canopy of the Oldest Taurtus on Earth was a little bit difficult to copy and did need several attempts. A learning curve I can use today and use for reference.
See post 98 page 4 last two posts of this page.
http://www.rcuniverse.com/forum/m_79...4/key_/tm.htm#
Cees
