RE: Wrongway Saito
Before trying to start it the next time set the LS needle 1/16th" below the flat surface of the throttle arm and the HS needle at 3 turns out fom gently closed. Do not prime firsr and then use the starter leting the engine pull the fuel up to the carb. Don't use the hammer on it, it is innocent.[8D]
