Cub Rudder help
I have a flitecraft cub and it is very hard to keep stable on the ground. Someone suggested to bend the tail wheel backwards in order for it to be more stable, but the plane tends to turn the whell to the front. The wire that holds the wheel is connected directly to the rudder and I feel it puts too much resistance on the servo. Any ideas?
Should I not bend the wire that holds the wheel at all or should I bend it backwards to make it more stable?
