ORIGINAL: mithrandir
ORIGINAL: anders12
A correctly designed and built all wood wing is lighter and stiffer than a foamwing and the compositewings seen in kits sofar.
As said many times, ''wood flies better!''
Anders J
based on the several composite wings I have seen to date....
Composite wings are heavier because they are simply not optimized. I doubt any of the composite ARF manufacturers actually employs an engineer to design the wing structure.
I could make a composite wing stronger and stiffer for the same weight as a foam wing....
I'm Sorry, but what you say is wrong.
Simply because we already use the lightest materials available.
Plus, We have to deal with the "ding" resistance if the surface, that is already rather poor.
Try yourself to make one and you'll see.
The only area where it is possible to save weight is in the more accurate use of the resin quantity into the laminate and the gluing. It's all a matter of skill and time.
