RCU Forums - View Single Post - 2.0b ECU PARAMETERS ADJUST
Old 10-26-2011 | 11:33 AM
jsouza
Default 2.0b ECU PARAMETERS ADJUST
Hi, all!
I've got an Electric Start Pegasus that came with 10S 12v NiCad battery pack. When the battery needed to be replaced, I installed a 4s LiFe pack.
For my surprise, the glow plug voltage changed to 3,8 volts and it is turned on (and melted) by the ecu at the time the switch is turned on.
Even with the melted glow plug there is no burned glow plug warning at the EDT.
As I don't have the cable to connect the ECU to the PC, is there any other way to recalibrate, adjust or even reset the ECU?
How can I adjust the ECU?
Jones
