RE: anyone use a ansmann xbase 2.0 se?
Its fine.. if you are using a lipo the max charge it can handle if its a 2 cell is 8.4 volts if its goes over then you are in trouble it will stay at 8.4 volts for ages until its fully charged..... just make sure you have it set to Lipo and you will be fine.. to be safe charge on balance.
If you are worried then watch the numbers go up.. if it goes over 8.4 then stop it straight away.. if u have the balance plug in.. the charger should have some safe guards built into it if it goes over 8.4 (4.2 per cell) or below 6 (3 per cell).. which is what you need for lipo 2 cell..
If you are only charging to 7.2 volts then you are only about halfway charged not even..
cheers
