RCU Forums - View Single Post - Tuned Muffler header length adjustments.
Old 10-26-2011 | 07:54 PM
resourcecapital
Default RE: Tuned Muffler header length adjustments.
if as you are shortning the additional pipe length if rpm drop it is still to short.
i tried this on a 45 size motor and it would not work.
timing on the exhaust port was not correct.
and yes the volume of the mini pipe is also a factor in generating the correct return wave pulse.
good luck let me know if you can get it to work
