RCU Forums - View Single Post - what 2.4 article
Old 10-27-2011 | 08:27 AM
  #224
Sport_Pilot's Avatar
Sport_Pilot
Default RE: what 2.4 article
ORIGINAL: warbird72
ORIGINAL: Sport_Pilot
ORIGINAL: warbird72
I do have mussle spassans tingeling in my arms.. I can't sleep at night either.. As far as the check out on the radio.. I checked it right out of here.. I then bought the first 7c 2.4. I bought it new from tower then had to send it back due to a bubble in the lcd.. But I do have 4 other 72 mhz systems all Futaba. ch 48 and 55. It's crazy I set up the plane on the 72 band walk around and glitch glitch bind. It acts as there is someone else on the same channel as me.. But I do have a scanner and on any given day no one else is on. Heck no one is on where I live.. But when the plane does this I hand the tx over to my girl and she can walk out of sight with no trouble at all. Then she will walk back I walk in between her and the plane full down and or full left or right aileron. I mean a full lock. It has striped gears because of this.. I take you have heard of this ??
I have had wrench's, cell phones, and other metal objects larger than your inserts near my transmitter. I suspect it is out of tune just enough that the induction from your insert puts it off frequency. I would send it to Radio South or the manufacture service center for a check up and tuning.
If it was a tunning issue why would everything work ok in the hands of another person?
Because the tuning may be off, but not enough to make it quit working withough your inserts. But this is only a hunch.
