Am I safe pushing a bit harder?
Flying a 2.5 lb airframe on a HET 2W-23 using an CC Ice 100 set at medium timing this is the data off of the ESC with a 5X5.5 apc prop. Given this motor is rated at 58 amps at 850 watts I am pretty sure I can try the timing at the high or hard setting, opinions?
