RE: TFL NTN600 Kiton Twin Setup?
Yes anything over 2000 on 4s will work in this size hull , my setup may be a bit hot its in a light weight carbon cevlar racing MONO 2 boat , if you went half way like an AMMO 2300 there a good cheap motor can swing a 40 / 42mm prop should give good speed .
