RCU Forums - View Single Post - what 2.4 article
Old 10-28-2011 | 06:07 AM
  #246
cj_rumley
Default RE: what 2.4 article
ORIGINAL: Oberst
Another way a MHz can fail is if the range between the outgoing and recieving signal is too distant, that's why the antenna needs to be pulled out, and we don't try to fly our planes out of range.
Pull out the antenna to reduce the range...........
I get it now!! It's just like using a longer shotgun to get closer to the ducks.
How cheap can the radio manufacturers get? AMAshould make a rule that requires longer antennas on 2.4 GHz radios, like the ones that used to be supplied with 72 MHz radios. Problem solved.
