RE: one for the engine guys
The smoothest running 2 stroke opposed boxer twin I've ever seen had a smaller displacement piston (30-50% of primary) driven in a cylinder about half the stroke of the main cylinders, oriented 90* to the primary cylinders. It was used to drive an accessory pump. You could place a glass of water on either of the primary cylinders and see only a little vibration at idle RPM.
