RCU Forums - View Single Post - what 2.4 article
Old 10-29-2011 | 02:09 AM
  #307
TimBle
Default RE: what 2.4 article
ORIGINAL: John Sohm
ORIGINAL: gsoav8r
I dont believe it will be anything higher than 2.4. Microwaves already have a hard enough time getting thru obstacles. 5ghz would only compound the issues. Anything less than 2.4 would be beneficial.
Not necessarily true. It depends on the band and what absorbs it. Seems to me that X-Rays and Gamma rays are way up there on the frequency chart and they don't have a problem going through most materials, especially humans. And no, I'm not suggesting using either of those so don't go there.
As I see it, it appears most of the individuals speaking here are speaking from conjecture and a somewhat simplistic understanding of how it all works. Statements earlier in the thread relating 2.4 GHz to light are just an example of, and please don't take this in an insulting way, the average person's ignorance of what the electromagnetic spectrum actually consists of. For a look at how it breaks down and where our systems appear in relation to it, you can visit this site for quite a bit of info even if you're not a scientist. http://hyperphysics.phy-astr.gsu.edu/hbase/ems1.html#c1
Having been an avionics communications specialist in the USAF, I can tell you that there are many factors that affect the propagation of any type of radio wave: frequency and power level being two of the major elements. On the receiving end, you have sensitivity and selectivity as your two major players. Sensitivity is how low of a signal can be detected and selectivity is how good it can distinguish the desired signal to other similar signals. That's why with the old 72 MHz, the AMA established safe distances between fields.
Today's 2.4 GHz systems eliminate some of the selectivity issues by the bind/link process where a transmitter has a specific code associated with it that the receiver constantly monitors once it is bound/linked to the transmitter. Reminds me of the old "I AM WELL" signals incorporated in older equipment. Sensitivity is the next item and the more sensitive the better. These systems are limited in power, and by nature are very directional. The problem is you don't have a directional antenna to focus the beam at the plane's receiver so you're limited to an omni-directional antenna to transmit the signal in all directions. This means that a lot of radio signal is wasted going of into la-la land and not being detected by your receiver. Right of the bat you're range has been decreased. Not necessarily a bad thing considering the systems are designed to work over a relatively small range (1,000 meters or so).
So where am I going with this discussion? I guess what I'd like to say is this, there are a myriad of factors that will affect any of our radio systems and to base decisions of what is best on sheer conjecture and speculation while embracing ignorance, is counter-productive to say the least.
This thread was opened by a simple comment regarding an article regarding 2.4 GHz and blossomed into a monster with all kinds of comments to and from and at specific individuals. I don't think this should be a Jerry Springer type thread.
Any way, if I offended anyone, I apologize now and if anyone wants to learn more about the electro-magnetic spectrum that surrounds us, check out the link above.
No offense taken. I think it was I who refered to it as "light"; a gross over simplification as Light is merely a range of wavelengths within the electromagnetic spectrum.
I merely used the reference to illustrate that we are sending signals using a band within the electromagnetic spectrum and that the area of the spectrum used is not the major concern but how the hardware detects what is transmitted and how the hardware discerns the transmission from background noise is what is fundamental to the reliability.
