RCU Forums - View Single Post - what 2.4 article
Old 10-29-2011 | 04:54 AM
  #310
littlecrankshaf's Avatar
littlecrankshaf
My Feedback: (58)
Default RE: what 2.4 article
ORIGINAL: Dave
<u>QUESTION FROM TimBle:
</u>''How is a Tx impound going to help?''
The 2.4GHz transmitter impound will help; here is why:
Range decreses as the number of clear channels decreases. Bandwidth drops each time FHSS encounters
a blocked frequency on a crowded spectrum. The crowded spectrum on the 2.4GHz band reduces the bandwidth,
increases the ever present background noise, increases the adjacent channel leakage ratio, reduces the range,
and causes overlapping. Overlapping is a direct interference.
Hmmm...is the worn out case of impounding 2.4/all radios the real thrust behind this thread??? I think so...
Some see the "frequency bored" as AMA's pulpit/alter for AMA religion at the flying field... If the crowded 2.4 spectrum was/is a real issue, a simple guideline for max number of pilots would suffice...instead radio manufactures have gone to great lengths to dispel that notion.
Yep, more about control than anything else it seems...and I don't mean radio control... Sad
