RE: Prop Question
I have the standard 10mm-12mm reamer made for RC applications and used it once. What I found is that the angle of the reamer to the prop hub may not be at 90 degree, at least at the beginning. I did not like the way the prop has a slight large hole at one side.
Maybe operating the reamer on a drill press is a better procedure?
