Joe,
I think you just gave everyone (new & old timers) some excellent advise on Turbine fuel system set up!!
Todd is also correct about the temp probe. I have had turbines sent to me for testing, and I have found the temp probes pushed into the tail cone to far, giving the ECU erronious readings. The proper distance the probe should be sticking out, inside the tail cone is 2-3mm only(on all KingTech turbines). It is a good idea to double check your probe while installing the turbine, to make sure it doesn't accidently get pushed/bumped in to far.
KingTech, USA
Dirk Flejter
Service Tech
[email protected]
