RCU Forums - View Single Post - what 2.4 article
Old 10-29-2011 | 05:45 PM
  #327
kenh3497's Avatar
kenh3497
Default RE: what 2.4 article
ORIGINAL: TimBle
my dad is bigger and stronger than your dad...<wipes nose.='''' from='''' snot=''''></wipes>
2.4 has more than sufficient range to allow safe operation of a radio control aircraft. People fly UAVS with the stuff and they fly well beyond 3000m (yes thats 9000ft)
2.4 is not used by cell phones, its used by Wifi, bluetooth and other peripherals.
the band our new rc equipment operates on is not the issue, its the implementation of the hardware. All computers have ''moments'' and our Tx are not immune. There in lies the rub. The 2.4 band is merely a wavelength of light, how TF can it be faulty??! This arguement is stupid.
''i used to work for XYZ blah blah blah''
I used to work for a military contractor and designed devices that required remote activation from a long way away. Hey we used the 2.4 band and many other bands and guess what?! They all frigging worked. The only time it stopped working is when either the hardware or software ''had a moment''.
FFS get over yourselves.
''Brand X and Y and Z and A and B also ahd issues this year...''
Heck how moronic is that arguement. Anyone can have an issue any time. What was the root causes of those ''incidents?'' Don't know huh?
More people have issues they can't explain and suddenly its the wavelienght of light thats at fault. Well lads unless the sun sent out more neutrino's 8min ago I can't see that only 2.4 is going to be affected.
Hardware/software, hardware/software.
PS not direct at you Ken
I haven't read every post in this thread.......
So far the quoted post makes the most sense. As far as "buggy" things we all use, Has anybody here ever us a computer operating system that has "problems" ???? How many years has it been since you have NOT had an OS problem? The same OS keeps having problems over and over and over. It's getting better, no doubt, but it's taking a while.
Bottom line, if it's man made it will fail or have an issue at some point in it's life span.
I converted my OLD JR X347 to 2.4 (Spectrum) and have had no issues. So I guess I'll just keep on flying it. And yes I wrapped it in foam and stuffed it under the tank in TWO airplanes.
another Ken
