RE: TT 07 again
Which model do you have, early or later model? How much pinch do have at TDC?
The later ones are better than the earlier ones, and they are close to a Norvel .061 RC on a 6x3 prop. With a turbo plug head it will slightly out-power the Norvel .061 but can not match the .074. So there is nothing really wrong with these engines (at least on the later model).
The o-ring on the needle is not diesel compatible, you'll need to get a viton ring or something else than the stock material.
You could also try a Norvel .061 with an RJL head instead. Less weight, no o-ring on the needle, and Norvel seem to run well on diesel too.
