RCU Forums - View Single Post - TT 07 again
Thread: TT 07 again
Old 10-30-2011 | 08:28 AM
Mr Cox's Avatar
Mr Cox
Default RE: TT 07 again
You could possibly cut a new o-ring from a piece of neoprene tubing, I think you do need a seal there.
The newer one has the three topmost fins of the crankcase with a larger diameter, and the alignment pin for the cylinder is also solid. I've test run mine on diesel, with a glow plug and all shims removed, it felt quite alright but the o-ring couldn't take the fuel.
Here is an image of the latest model:
