NEW Jetcat USB cable 2.1
New USB cable for Jetcat ECU Ver 2.1
we updated the USB cable a bit with new firmware
now does not need special drivers anymore.
make sure you have windows autoupdate enabled.
Windows 7 will autodetect the cable as a rs232 cable.
make sure it installs it at lower com port value (com 1-5)
if they are higher the jetcat software may not detect the cable
if so:
click on computer / mouse right button/ select properties
devices
select the comport it installed it on
click on details
then advanced
now select a new comport for it com 5 should work fine without getting into trouble on other comports
specs :
USB/rs232 2.1
cable with RJ 11 connector
length : 2 meters
available : Jetcat dealers or Jetcat direct
