RCU Forums - View Single Post - Sebart Wind S Pro
Old 10-31-2011 | 12:28 PM
  #438
talk the torque
Default RE: Sebart Wind S Pro
ORIGINAL: hezik
First thing to say is:
do NOT use the supllied hinges!
They are crap, yes they are, all of them. If you have 20 of them, 15 will come with backlash right out of the box, the other 5 will develop this in the first few flights.
In the beginning of this thread, there are several people telling how they used those hinges without issues, don't believe them, this isn't true. If you want to fly masters, you will notice sloppyness on those hinges.
I did install the original hinges and had to replace all of them. I did this by simply drilling them out using a dremel and a 2.5mm drill.
Only problem I encountered; in the ailerons; once you drill the original hinge stub out of the aileron, the last piece of it, which sticks through the wood and therefor is nog fixed to anything, will fall into the aileron, without any way to get it out. The solition to this is to wiggle your aileron so that this loose piece is close to the hole you drilled, and then drop a few drops of thin CA in the hole, glueing this loose piece to the aileron on the inside.
It's either that, or cut open the aileron on several places to remove them.
When mounting different hinges, ie the robart hinges, make sure that they are supported all the way up to the actual hinge-point, or you'll still end up with some backlash.
Hi Hezik
Can you give some more info on the gluing the bits of the old hinges. Both my ailerons, both elevators and the rudder now sound like a rattle. Its going to drive me mad everytime I carry or turn my plane over [sm=confused.gif]
I cant get the hinge bits close to the hole as I cant even see them even when I shine a torch down the hole. I have used cyno with a long spout and basically squirted a bit into the hole holding the surface vertically so that the hinge bit comes against one of the inner ribs and the cyno would help it stick there. I got all the rattles out and was really chuffed until I started doing the rest of the hinging and as I'm working with the surfaces the bits are coming loose again [sm=angry_smile.gif] I dont want to keep pouring cyno down the holes... help [sm=drowning.gif]
