RCU Forums - View Single Post - What are boost tabs???
Old 10-31-2011 | 05:00 PM
  #32
Rotaryphile
Default RE: What are boost tabs???
Wobblewobble mentioned having crashed because of a boost tab. I had my rudder servo linkage disconnect once, and the rudder went hard over - more than 45 degrees, with a very large 3-D type rudder. I had to fly the airplane in knife edge to a gentle upwind crash landing that slightly damaged a wingtip. I had been experimenting with the travel of the passive boost tab, where the servo controlled the rudder directly, with the tab assisting.
It turned out that the tab was too effective, causing the rudder to slam hard over when the resistance of the servo was removed. I simply reduced the travel of the boost tab, and everything was OK. The rudder had been a bit hard to trim, because the tab was forcing the rudder to uncommanded movement within the slight slop in the control linkage.
